Incorrect glass edge color calculation in V-Ray (comparison with Corona)
Thanks for testing! I tested your scene, and you’re right — in your setup, it actually works the other way around. I got 2x faster render times with the Dome Light, even when using a Color Correction node.
I tried your suggestion with a clean HDRI loaded directly into the VRayDome (no Color Correction node) and set the Inverse Gamma to 0.5. However, I still got the exact same 5-minute render time instead of my usual 2 minutes. With auto i get 2 min. Auto + 1 color corretion just saturation -50 get 5 min.
Could you please try rendering my scene on your setup when you have a moment? I’m really curious if you’ll see the same performance drop on your end.
Sure I think I could do it at night, Ill let you know.
I think that for this case that youre using it for animation, definetely go for what it works for you in order to get the fast render time per frame.
Ok I did some quick tests in your scene. I just replaced the camera and set up everything as default except for LC and path guiding as the prior examples. For what I can see there are some inconsistencies, but it depends entirely on the Dome multiplier and Environment output.
If I use Dome multiplier by 1 its a little faster than Environment with output in 1, if the multiplier and output values are increased, render times also increase by a lot, where environment has doubled its time from Dome, but for some reason I liked more its light ressult bit not the color. I couldnt get the same ressults, I wonder if just using the camera exposure would do a better job or something from the Dome.
The main issue is when using color correct and Gamma inverse, it seems faster in Environment. I also tried just with sun+sky in a dome with full clouds in order to get similar ressults, the quality is improved by a lot but its rendering time its not “ideal”.
Ill try to test it with camera exposure if I could get the same shadows that environment has with no CC. I have read the other thread that you posted and Im glad to hear that you found something that Vray team could improve.
I attach the scene and the render times from the experiment (read it from bottom to top).
HDR Dome Test 02.zip (1.3 MB)
