lowest value in contrast (0.0) still not enough for me in my regular work, while in other hand max color correction has maximum range.
devs, regarding you are improving corona colorCorrect, do have a plan to implement this feature request in the nearest dailybuild?
As far as I understood contrast 0 is not low enough for you in the Corona Color Correct, but in the Max Color Correction you mentioned a maximum range. Can you explain it? I just do not understand comparing the minimum and maximum values.
Can you post some examples of where you would like to use this feature?
i’m sorry, my mistake, i posted an incorrect sentence.
this is the good one ![]()
- corona ColorCorrect contrast lowest value (0) isnt low enough for me. compared to max colorCorrect.
- corona ColorCorrect brightness lowest value (0) and higher value (1) both are not enough too imo. even though it shows different color compared to max colorcorrect.
i’m hoping i can completely replace max colorCorrect with corona colorCorrect.
