First of all, I’m using GPU and intend to keep it that way.
HDRI image from hdrihaven (‘tiergarten’). It’s 8K. I also tried the 16K.
The problem is in order to make it higher resolution, I need to increase the Dome Light “Tex Resolution.”
This image the Tex Resolution is already at 10,000. When I increase it more, I sometimes run out of GPU memory (2x GTX 1070 Ti).
Is there any other way to increase the HDRI background image resolution other than cranking up Tex Resolution?
Should I give up and just a) model the trees or b) photoshop the background ?
Hello @joey145
I would like to propose the following solution instead:
- Go to the V-Ray Asset Editor > Settings tab > Environment;
- Right-click and Clear the default texture from the Background texture slot;
- Paste the HDRI as a Bitmap in the Background texture slot, enable the GI, Reflection and Refraction and Copy+Paste As Instance the HDRI in their texture slots as well;
- Adjust their intensity values to a higher number if needed. In my tests, values of 25-30 looked much better than 1.
Please let me know if this workflow enables you to utilize the high resolution of the HDRI file.
Thank you @Zahari.Ivanov ! That works much better!
