incredibly noob problem.
ok this is wierd. i have a massive bundle of splines. ive attached them into a single spline object. i go to “spline” subobject, select one, try to move it.. the whole object moves..?
wtf? there is nothing unusual or non-standard about this scene.
on a related note, the reason i wish to select the subobject is to move it. ideally id like to use randon-transform to shift all the spline subobjects randomly, but i cannot find a single randomiser tool that works with spline subobjects. even the “spline toolbox” script will only randomise vertex or segment positions.
have i missed some major limitation of spline objects for all these years?!
Do you have to have them attached before you randomize them? You could export the object as a dwg, import this using “derive AutoCAD primitives by Entity”, randomize and then attach perhaps.
thanks for the reply.. thats a nice trick to separate the splines! im sure it will be useful one day.. in the end i went back to an earlier version of the file before i had attached them, as there were some other tweaks i needed to do too. still a mystery why i couldnt select a spline from the object and move it independently… never happened to me before.
