Infinite Envionmental Grass Map won't work in 1.48.94
Greetings to everyone!
Can someone tell me why the infinte enivronmental grass map that Micha created here in the Forum won’t work in the new versions (1.48 above)? Does the UV mapping system have changed?
Re: Infinite Envionmental Grass Map won’t work in 1.48.94
We’re still trying to figure that one out ourselves. It’s been reported by a few users that the method Micha described doesn’t work in the latest version. Hopefully we’ll have that fixed sometime soon.
Thanks for the response, Devin!
Another thing that I’ve tried to do without success in .94 was rendering a animation. When I render the scene, my scene tabs renders normally, as I see the frames rendering one after another. But, the auto-save options does not work, as it saves only the first frame of the animation. I’ve already checked if the file name or the save path contains non-english characters, and they do not contain.
You should enable the option called “include frame number” located on the output tab.
Thanks, Fernando, now it’s working..
Is there some news about that grass technic ?
I used to use it on the previous version of Vray :slight_smile:
We still working on this
Up :slight_smile:
Is that working in the 1.49.01 version ?
I can’t get the environment grass to work in vray 1.5. Is there a solution?
No, We haven’t fix that issue.
