initial fill, object: Maya
I am using an object as an initial fill source. My issue is that at the moment once the simulation starts the amount of liquid shrinks down to only 20-40% of the objects volume.
Is there a way/setting I can use to ensure that this amount does not ‘compress’ in this manner so much.
Thanks!
Hey,
More steps per frame and a larger scene scale help the liquid settle without too much jumping up and down - give these a shot if your values aren’t already high.
Cheers!
OK. It isn’t jumping up and down though. It just shrinks/compresses downwards. It isnt a problem I have when i set an initial fill on a simulator - only if i set an initial fill on an object ( on the additional node properties ).
I set the scale to be 5x what it was, and the steps to be 1/5 - but still the same effect.
2 images to demonstrate: fr 1 of simulation and fr 20
I can see whats going on now, If i look at it side on I can see that it is filling the initial volume like a shell and is hollow in the middle.. I have no idea why.
OK. Figured it out now. The source mesh was too close to the collision object. Once i shrunk it a lil The object was filled like a normal volume.
edit: Nope I stand corrected. Its still behaving as though its a shell.
Ah yes - here is a way you to approach it which could save you some time modelling - Chaos Docs
Yep, reversing the normals did the trick.
Thanks!
