Yeah, I already gave the cloth object some volume by adding a shell modifier, that isn´t the issue here. I really think its about the speed the vertices have. Like I said: I could probably do some more tests with higher SPF, but unfortunately I ran out of time again and I gotta wrap it up. I ended up going the Fake-way and used a snapshot of the cloth object in its torn state as collision dummy. I´m missing a bit of dynamics now (I couldn´t get the plain force to work like I wanted to) and I´m still missing detail, as you can see:
Here are my settings:
Vorticity is at 0.1, so maybe upping that might give me that extra level of detail. Or my scale is still off and I need to adjust that, OR I need to increase my grid resolution…
And I´m also not using any buoyancy, I don´t really want the smoke to rise up, but rather sink down (towards the camera), not sure how that influences the look of the sim…
Hm, I´m also not sure about my opacity curves now. I just switched to simple smoke with smoke factor at 1.0 and it looks much more massive now…I´ll play around some more with the render settings.
I also just read about the displacement option in the manual. I only used this for liquid sims before, I didn´t know, that it was possible to use it for smoke and fire aswell, the added detail looks great in the examples!
I couldn´t figure out how to make it work though, I used the Phoenix tex map, used the velocity of the sim, then plugged the map into a composite map and multiplied it with a noise map and used the composite map in the displacement slot, but the result looked in no way different.
Do I need to consider anything else here?
Ok, I didn´t check the velocity channel in the Output settings of the sim, thats probably why I don´t get any results with the displacement…
Hey,
Sorry for the late reply! In the video the velocity acts like the discharge still continues after the first frame.. If you like, you may drop the scene to Support and we’ll have a look.
Cheers!
No problem, I finished the project already and am quite happy with the final look (see attached file).
The discharge isn´t actually stopping after one frame, I just dropped it from 20 down to 2, so thats why it looks like its still emitting…
The smoke could have looked even denser, but that was probably just the render settings and maybe I could have simmed with even more grid cells and increased the vorticity a little further. Also I´d still have liked the smoke to slow down even more after the first burst. Wasn´t there a setting like “air restistance” in a previous build or am I imagining things? Because increasing that value would probably be the closest thing to simulating an underwater environment. Or would it actually be possible to simulate smoke in a liquid container?
I also realized at some point, that I already had made the exact same setup in a previous project, I was even happier with the result back then, so I´m gonna take a look at those settings again…(see other attached file).
Sweet! Very organic looking
There wasn’t an air resistance, but maybe we need to add a similar option. I was just experimenting with ways to increase the inertia of rolling smoke, so this might be a single control that goes both ways…
Cheers!
the air resistance is directly controllable by the smoke temperature when uniform density is disabled.
cold and hot smoke produce very different result, the hot smoke expires bigger air resistance than the cold one
This would be a very indirect way to approach it and won’t work in all cases though.
Thanks, I´ll give it a try next time! Uniform density was always enabled I think, so I guess the smoke temperature didn´t do anything. Its always hard to get dynamics right, when your don´t know much about physics…
But I have to say it once again: I just love how versatile Phoenix is! I´m constantly trying new ways to squeeze phoenix into our projects and from the feedback we´re getting I know that our clients love it…
Very happy to hear, I hope we’re getting there
