install help
I am on Centos 7. I am running Nuke 10.5.4 noncommercial. I just downloaded a 30 day trial of v-ray for Nuke. I ran the installation. It seems like it worked. When I run Nuke I can’t see the vray plugin in the “All Plugins” menu. I don’t see a .so file anywhere for vray. It has to be in the Nuke pluginPath, right? I poked around and tried to make sure the license was installed correctly. It looks like maybe I’m missing a .crt file?
[jpatterson@darkczar OLS]$ ./vrlctl online enable
> Reading config from /home/jpatterson
Error: missing parameter “crt”. Please specify path to the downloaded certificate
I had installed the license server but not the plugin itself! Doh! I ran vray_trial_35002_nuke10.5_linux_x64 and things are working the way they should.
…except that custom plugins are not supported in noncommercial Nuke! D’oh!
AFAIK Foundry have 15day trial for full NUKE.
