Install question
This might be a bone head question but it has been awhile since I
have asked or seen a post about it but…
I have 24 slaves and at one point in the past you had to manually remove
all the plugs and VRay files manually before installing the newer version.
Is this still true or can I overwrite and not worry about it? It can be a real
hassle removing the files and installing on multiple slaves.
no, just run the installer. my last update was “.03i” and it worked fine, didn’t even have to reset the spawner :slight_smile:
