Installed latest preview
And now I can’t run Enscape. I get the .Net Framwork 4..5.2 error message, which is already installed on my machine. Thoughts?
sorry, is not an answer to your question but for dummies and beginners like me
  • we can always overinstall a previous version again?
Yes…you can. I uninstalled Enscape and reinstalled the latest version. I was hoping to test the gi flicker fix in the preview, but apparently not.
Thank you for clearing that up for me.
And yes, i hope that they soon find a way to banish this blotchiness within interiors …
@vjaramillo_cg The message about a missing .Net Framework can also be caused by a corrupt installation. So just execute the installer again with all SketchUp instances closed.
If this does not help, install a previous version and send feedback, adding a link to this post. I’d like to take a look at the log files in this case.
That worked… Thanks.
So…I noticed that with the latest preview, the quality in the Enscape window doesn’t res up to a clean image? It stays grainy. Is this because this is still a preview?
Right. It does not deliver a full quality image render. To do so, you have to trigger a render by saving it into a file. We will release a preview soon that will bring the resting quality closer to rendered saved image quality.
