installed vray 5 for sketchup and... no materials
like i said there is no materials iinstalled… is it a known issues? thanks
We’ve received a couple of reports already, meaning you are not experiencing an isolated issue.
Could you please double-check if your network-monitoring tools (firewall, anti-virus software, etc) are not blocking V-Ray’s UI:
C:\Program Files\Chaos Group\V-Ray\V-Ray for SketchUp\extension\vrayneui-win32-x64\vrayneui.exe
Additionally, please state whether the new Light Gen tool operates as expected and is able to donwload its HDR assets (V-Ray for SketchUp)
Last but not least, providing log files may help in finding out what is blocking the asset retrieval. The files needed are:
VRayForSketchUp.log located at %AppData%\Roaming\Chaos Group\V-Ray for SketchUp
vray-neui.log located at %AppData%\Roaming\Chaos Group\V-Ray for SketchUp\vrayneui
Just in case, please do a clean reinstall of V-Ray 5 for SketchUp and make sure you don’t use admin privilege when running the installer.
Kind regards,
Peter
@cognedur I encountered this issue and solved it by disabling my antivirus protected folder security (BitDefender), just as @Peter.Chaushev mentioned.
The option to download the assets will not be available if there are write permission issues.
Regards
Hi kyle_henderson,
Thank you for sharing this.
We’ll try to handle this case in the future and at least let users know what’s going on.
Konstantin
@cognedur , the v5.00.02 hotfix that was just released contains change that should solve your problem.
You can download it at Download | My Chaos
Please let me know if this works!
Peter
YES… it’s working properly now :slight_smile:
Thanks for the response
Cheers
