Is it possible to have vray installed for multiple max versions at the same time? I have 3dsmax 2012 installed and vray for it. Today I installed 3ds max 2014 in trial mode to see if all my required plugins works with 2014. When I was installing vray it says at the beginning that vray.exe is running and can’t continue with the install. I have no idea what vray.exe installer is referring to. There is no vray prosesses running. I have booted my machine several times and tried to install after reboot but I get the same message every time. So is it possible to have vray for 3ds max 2012 and 2014 at the same time? If I have to uninstall it before installing for 2014 then I am not doing it at all.
