Installing Corona Materials
I downloaded a material from ‘corona-materials.de’. I’m new to C4D/Corona so still figuring out how to add materials. I navigated to the C4D file that the corona material was supplied as. I did this using the Content Browser. I then dragged the c4d file from the Content Browser to the Materials area. It brought the shader attributes but none of the associated texture files.
Hi, that might an error from the user that created the material. Can you share a link to it? Generally, I would open the file in Cinema, check that the textures are loaded before dragging it to the content browser. If you drag it to the content browser and you notice a folder called “tex” is generated, you can be sure that the textures are linked with the material.
