Instancing = massive memory consumption?
Hi there,
I was wondering, on a large scene, I’ve instanced about 4 or 5 V-Ray proxies around the ground (in the thousands) and I’m getting around 12g worth during my rendering and very long render times. I’m using spPaint MEL to initiate the instancing and scattering the objects around:
However when I delete all instances and have just the original V-Ray Proxie and render, the render-time is quick and memory consumption is reduced to an expected 3-4gigs.
Maya 2013.x64 and
[2013/Feb/6|14:13:56] V-Ray: V-Ray for Maya version 2.25.01, revision 22704 from Feb 4 2013, 02:47:14
[2013/Feb/6|14:13:56] V-Ray: V-Ray core version is 2.00.02
Unfortunately the scene is too complex and large to upload anywhere. Has anyone else noticed this? I was under the impression that the point of instancing geometry was that each proxy shared the same memory?
Just confirmed, I seem to be getting the same “problem” with geometry instancing via Maya’s particles.
I can’t seem to recall this ever being a problem, hopefully this is just something to do with the latest nightly :slight_smile:
Expected result, I have “Skipped Rendering” the 20,000 proxies
Bad Result, I have enabled rendering of the 20,000 proxies and V-Ray seems to be unable to render and memory consumtpion was still climing over 10gb before cancelling
Can you get me a scene for this?
Okay, I have trimmed the scene down to bare-bones, I have sent through the scene to your email with the same subject line. :slight_smile:
Thanks we can reproduce the RAM usage here and we are looking into it.
