I`m running into issue using user attribute converted to float in shading networks.
See attached scene and render, i`m using integer attribute named class to drive rotation of the texture. Simply to get variation in shading per element.
If the integer is converted to float, it will produce artifacts in render.
When i use user float, but load integer instead, it works as expected.
Todays nightly W10, let me know if you can reproduce it.
So, the “fix” is to use TexUserFloat for that case.
Details: attributes are stored as map channels (value per face vertex); those values are interpolated at hit point.
In case of querying “int” value may be interpolated as (52.0,52.0,52.0) which will become 52.
However floating point computation may interpolate it as (51.993,51.993,51.993) which is basically the same float value, but “int” may become “51”.
That’s why it’s better to use user float directly without intermediate conversion in that case.
