Intances And vray..
Anyone have had problems using massive poly instances?, when i select instanciate in system tab and render the machine need very much ram that with replicate… and also several dark splotches appears.. any suggestion?
i dont think its the instance…dark splotches due to material error…
this is normally due to deffective geometry. flipped normals, double sided, or mirrored instances. I thought it was somehow fixed. Check your materials, (force double sided, etc).
Good Luck.
all my mats are vray ones, but happens with mirrored instances? i have used some of them, may it be the problem?
yup it can be. try using the mirror…opps wait, i just caught myself. its an instance. if you use mirror modifyer it applys it to the other instances as well opps
