what does this mean? Whats new in Scatter 4?
Thanks.
Hi @Jiri.Matys
We’ve reworked the UI a bit so it is more user-friendly - you can find our Chaos Scatter documentation page updated with information, and here is a list of some new cool features you could try:
- Limiting Slope and Altitude - You can limit the scattering of instances to the areas within specific slope and altitude ranges using the built-in limitation options in the Surface Scattering rollout
- Look At - You can make all your scattered instances point towards a single object in your scene using the Look at option under Transformations > Rotation
- Scattering Groups and Hierarchies - You can add a group or a hierarchy of objects to the list of instanced model objects with a single click
