I am in need of a quad core system with a shed load of ram asap and I am scared that if purchase one now the price will drop significantly and I will have lost out.
Do we have any confirmed dates as when the drop will occur and by how much at retail?
you can get a Q6600 +4GB Ram and MOBO for about £550, if intel drop it can’t drop that can’t drop more than guess £150 (off the total) which in the scale of things is not much. Just go it man,
I’m not sure if the $266 Q6600 price drop has actually been confirmed, but it would be a stellar deal; it started out somewhere around $800 at the start of the year.
definitely using a p35 motherboard, either asus p5k or a gigabyte ds3 / 4 are the winners. just need to choose one with the features i want and nothing more.
3.2ghz is a small over clock -
P35 chipset (and certain boards) supports ddr3 and ddr2 but its probably way too expensive.
looks like the q6600 is the way to go for sure, because the new q6700 is twice the price for a slightly faster bus.
I sent my dad out to Scan this morning to get one! haha
I have been to Aria as well to get some of my other bits and then to MicroDirect later to get the rest.
For pretty much exactly £800 I have specced:
Intel q6600 2.4ghz core 2 quad
8gb ddr2 800mhz Patriot memory (4x2gb)
2x 250gb Samsung SP2504x (for use in raid)
Abit IP-35 motherboard
Corsair 620w HXV2 Power supply
Thermaltake Soprano Piano black case
Arctic Cooling freezer 7 pro cpu fan
I can’t wait to get it built tonight!!! It should fly!
I am considering getting an nVidia 8800 gts to go in it as well but I am unsure which one to get. I have a budget of about £200.
Any ideas guys?
Ok thx.
Do any mobos support dual q6600s, or is that just being greedy?
not that I am aware of, if you want the dual cpu setup you threfore need the xeon series and you will be looking for 2 chips like the following Intel BX80562X3220 Intel Quad-Core Xeon Processor X3220 2.4GHZ
note the X in the name.
