After I decided to rerender floor. I set Render selection: Viewport selection, then selected floor, updated it material (for better understanding I made it with solid color on diffuse) and hit render.
Beauty pass, it’s ok:
And alpha:
Enviroment LightSelect element, it’s ok too:
Ceiling LightSelect element, it’s fine:
Summary, Interactive LightMix element, that should be the mix of two previous elements contains the old floor, from the very first render, that was made before I update my material:
I have exactly the same issue (pretty big one when you attend to save time rendering just a wall to present a client different versions ). I was about to write a post when i saw yours …
I’m using the last version of corona & 3ds max too.
I have trouble reproducing this. Can you send me step by step instructions?
Here is what I did:
Created a scene with a teapot, two lights, and a box as a floor.
Assigned textured material to the floor.
Set up LightMix automatically.
Rendered the whole thing.
Stopped rendering.
Adjusted LightMix.
Closed vfb.
Changed the floor material to solid color.
Enabled render selected > viewport selection.
Selected the floor object.
Disabled “clear vfb inbetween renders” in system settings.
Rendered.
Checked beauty and LightMix.
Yeap!
I think I know what is it.
When denoising is enable, Interactive LightMix element chages only when denoising is finished. Is it bug or just a feature?
I made simple video to describe this situation better. Sorry for my english
