Hi folks. Everytime I tried to rotate the perspective scene while the Corona interactive window open besides it, Max 2015 crashes. Could it be a graphic card issue, or just infamous 2015 bugs?
probably not a GPU error. Can you post the minidump 3dsmax produces (or multiple ones, that would increase chances for quick fix ;))
edit: https://coronarenderer.freshdesk.com/support/solutions/articles/5000524006
even in that case you can create the minidump - see “2. Reporting Error Messages” in the guide I linked
I have learned a new thing
The dump file (250mb) is being uploaded right now. Soon it will be arrived. Thank you.
Done! 1425083785_3dsmax.dmp
hm, there is no useful info in the minidump… only that it happens when working with some bitmap :(. Try the daily build, there was a bugfix regarding interactive
have you tried the daily build? - Daily Builds 1.0 - 1.4 - Corona for 3ds Max :: Previews (Daily Builds) - Chaos Forum
any progress here? If you cannot provide more info, I will have to close this report.
