Interactive renderer Issue
Hi I wonder if anyone has encountered this issue:
Working on a large scene, everything is going fine, worked on it many days and all good.
One random day, open up file same file, start interactive renderer, and the stats don’t load in the VFB, it renders, but I can’t do anything. Exposure doesn’t change, nothing. But it’s still rendering. If I try resizing the render window then it gets stuck. But I can still close the renderer and keep working.
When this happens, new scenes still render fine (as long as they are basic scenes). If I isolate a single object and render from the problem scene, it all works fine. The moment I exit isolate it gets stuck and stats go dead.
One thing I noticed is when this happens the CPU fan doesn’t spin up to the same RPM as when it does render normally (fan noise is lower, but task manager still says 100% CPU usage)
Sometimes remerging the scene into a new one fixes the problem, sometimes it doesn’t.
As it randomly comes on, it randomly goes away too. I might open the same file a couple of days later and it works great.
Anyone have this issue?
Windows 10, Max 2020, Corona 6.1
Could you be more specific on the file you are working on? What is in it? This all seems to vague to give an answer.
