Interactive rendering and max passes - no stopping
Status: pending
If one has max passes set for interactive rendering, the stop buttons dissapears when it’s reached that max number of passes. And if one for some reason doesn’t want it to continue rendering, there’s no way of stopping that other than making some change that will provoke interactive rendering to restart so you get the stop button back, atleast until it reaches the max passes again.
Submitted on AHA Ideas (CMAX-I-71).
I’m not sure what’s going on here and why I couldn’t enter a description and why it posted when i pressed enter in the summary/title field… Anyways, if one has max passes set for interactive rendering, the stop buttons dissapears when it’s reached that max number of passes. And if one for some reason doesn’t want it to continue rendering, there’s no way of stopping that other than making some change that will provoke interactive rendering to restart so you get the stop button back, atleast until it reaches the max passes again.
Submitted on AHA Ideas.
I copied and pasted from the comment into the description :slight_smile:
Also to clarify, I believe what you would like is for the Stop button to remain active and not greyed out, so that you can tell IR to stop after it has reached max passes and has paused rendering until anything changes?
Pretty much, it would do. But I would have rather distinctly different buttons/symbols for rendering and interactive rendering, so that a user can see whats going on, and the one for interactive toggles on/off for interactive.
A lot of times you want to stop the IPR cause you want to make a bunch of changes to materials and don’t want it to refresh constantly. But your only option is to close or move region to hit stop button. Many times you still want VFB open for reference. The IPR reaching it limit and stopping isn’t actually stopping IPR, cause any new move refreshes IPR. Can we always please have the option of clicking the STOP button.
Submitted on AHA Ideas by Don Farese.
@guest @Tom Grimes (https://chaos.aha.io/users/7263128047883613617) users would like this:
start IR > wait for the max pass limit to be reached > without re-triggering IR, make some changes to the scene like camera movement, object movement, adjusting materials
Currently this is not possible. It kiiiind of makes sense.
The Jira task was canceled.
Submitted on AHA Ideas by Marcin Miodek.
AHA Ideas status: Pending.
Set during AHA Ideas to Discourse migration.
