Interactive Rendering does not update Corona 10 Hotfix 1
Hello there I have installed Corona 10 Hotfix 1.
And what I hae noticed the IR does not update all the time when I change the Color Correction (node) > Advanced RGB color value. The IR does not update.
What I have done is uninstalled Corona 10 Hotfix 1 to my previous version Corona 9 Hotfix 3 and that issue does not exist, whatever I change in the Color Correction node everything updates instantly in Corona 9 Hotfix 3.
The fix for that in Corona 10 Hotfix 1 is to actually move the camera or rescale the IR Frame Buffer smaller or to bigger and it will update. Which is a bit annoying. Corona 9 Hotfix 3 does not need that.
What is the Color Correct node being applied to? The HDRI/Corona Sky, or some material in the scene? Is it only that one Advanced RGB value, and other values update as expected? Thanks!
I am unable to reproduce this issue using 3ds Max 2024 and Corona 10 HF 1.
Can you DM me a simple scene and some repro steps so I can try reproducing the same issue on my end?
