still needs a ton of work
Amaaaaazing!
the ambient lighting is by Corona sky?
no, it’s just constant color
When? When?
Right now i’m loosing hours just renderings previews, after previews just to position a light … when will be available ?
This is awesome …fast and responsive …I can’t wait .
Awesome mate! Thanks a lot! ![]()
That’s great, it seems to be really fast. ![]()
Great addition.
dont bother with activeshade, it is far from being at least a bit usable ![]()
looks fantastic, keep going with the great work.
Cheers
Realy fast. Fantastic!
This is PT+PT, right? Also is it in your plains CoronaRT in DR? This can speed up a lot our workflow. I don’t image how nice it will be play in RT with 10 nodes!!! XD
I disagree with you, cause VRay-RT (CPU and GPU) works very well (and fast) in DR! If you have 10 PC, the interactivity is very good. ![]()
…you are a great Ondra!
it could be great if it was built in the application (so only commands get sent to render slaves, not entire scene). But I have my doubts how useful it will be with 400MB scene if it gets send every time you mode a teapot…
I don’t know how, internally, VRay-RT works. but it’s a very good “boost” know that I can render in RT with all my nodes.
Honestly, I didn’t use too much VRay-RT, cause it don’t support all the VRay producer features.
Many times, it was faster to do some tests using fast LC with low settings, instead of using V-Ray RT.
For example, to initialize VRay-RT with heavy scene, we needed 30 sec or 2 minutes.
With regular VRay 10-15 seconds…
This is pity.
I hope Corona-RT will be faster!
there isn’t and never will be anything as “Corona RT”. The interactive renderer is and will always be exactly the same as the one used for final renders.
