I found that when using clone + step effect, interactive rendering it can not be seen, but the final rendering can be, I know this is a bug, interactive rendering does not support step effect
OK on my end too, I thought it may be an issue with the cloner set to multi-instance, but that’s working fine.
Is there any thickness to these sheets?
If you can share your screen, that would be great! I have tried to recreate this but can’t get it to not render.
I’m sorry that I don’t have permission to share the screen with you, but I can send you a test project, thank you
That’s fine, if it’s reproducible in a test scene, that’s more than enough to send us.
I think it’s a bug in the time offset of the step effect
test.c4d (264 KB)
Thanks! We have this logged now.
(Internal ID=1141233642)
