Hey I’m experiencing a lot of lagging when using interactive rendering even with a low resolution, any idea what I can do to speed things up?
Whatz the setup?
Knowing more about your scene would certainly help. ![]()
My setup is AMD Ryzen Threadripper 1950X, GTX 1080TI, and G.Skill 64GB 2999 MHz.
The scene doesn’t seem to make a difference because the problem occurs whether its a big scene or small studio shot.
Could you send over a scene you are having problems with? The simpler one would be good
You can use the private uploader Chaos
Also, in this instance, it would be great to see a video capture of what you are experiencing, so we can see just what you mean by lag, and when it is happening (and we could then share our results with your test scene for comparison).
