Always get the crash when i try to replace texture file with running Interactive Rendering.
Corona 5 + 3ds max 2020
Hi, can you please explain what exactly you mean by “replacing texture”? Can you provide simple steps how to replicate this issue?
Also, if 3ds Max crashes for you, you should be able to capture a minidump file from the crash (regardless if the Autodesk Error window is there or not). It’s really simple. See here for instructions (points 1 or 2 depending on the case):
https://coronarenderer.freshdesk.com/support/solutions/articles/5000524006
Same here.
Have IR going > Change a bitmap of a texture > Crash
I mean literally when i replace texture file (in material which scene uses) no matter how, drag and drop into the slot or pushing button, it always causes crash.
This is quite old problem, first time i faced with it years ago
Which version of Windows are you using? Can you also describe whether you are using a 3ds Max bitmap or a Corona bitmap?
In this situation, as well as sending us a minidump, a short video showing your reproduction steps might be useful too.
Thanks,
Rowan
Windows 10 Pro 1909 (Currently)
Both
Okay, in this case can you please send through a minidump from the crash, your scene in question and some specific reproduction steps?
This is the only way we will be able to fix the issue. Instructions on how to do all of these things can be found in my signiture.
Thanks,
Rowan
I tested this on three different pcs, they all had win10 and corona 5 + 3ds max 2019 and 2020. This is definitely a global problem. Just check it
The reason I asked for the above is because we are not able to reproduce the crash here on our machines.
So there has to be some specific step we are missing in trying to reproduce it..
Please can you provide a minidump, scene and some specific reproduction steps?
Here is a helpful guide of what we ask for when reporting bugs to us ![]()
Thanks,
Rowan
@OP - so here is a video showing replacing of 3ds Max Bitmaps and Corona Bitmaps while interactive rendering: Dropbox - Error - Simplify your life
Nothing is crashing/freezing, no problems whatsoever.
I am afraid we will need better reproduction steps than “just check it”. The more details, the better.
Perhaps this is when using networked textures. It happens to us, but I have not tried this from local textures folder, all our stuff is through network.
Dave
Are you trying to update or replace a PSD file or you are getting crash with any format? Does it happen both with bitmap and coronabitmap?
I never had issue with replacing file in material editor, but crashes are very frequent when file is being updated or deleted. But, this probably isn’t the right place to discuss/report that issue?
Ok, so the small detail about the textures being loaded from the network was kinda important. ![]()
We will look into this again.
Ya haha. I guess I have just worked from a network pretty much my whole career, so it just slipped my mind.
Could not reproduce. We will need exact reproduction steps or a video. What I tried:
