We have a web based project we are currently working on which is a collection of 3d rooms that will be navigated through by the user using flash. Below are the work in progress renders which we wanted to post and welcome all constructive comments and criticisms so we can feed them back into the project and make any improvements!
Many thanks for taking the time to have a look and hopefully provide feedback!
So will the path be prerendered? Or is it more like a papervision implementation? Depending, I think the renders are looking pretty good! The lighting on my monitor is a bit blown out in some cases, like the bottom ceiling image. Also it looks like some of the images could use a higher IRR Map, as there’s a bit of splotchiness in the corners…I think I like the kitchen scene best.
Thanks Eric - it will be pre rendered paths the user can navigate along - the reception area in particular is still being worked on and things like the red wall, furniture and light settings (as you have picked up on) need a little tweaking! Will modify the IRR map thanks!
I agree with the previous statements. Once corrected they will really help the images. My favorite is the office with the brick wall on the right hand side. I think that wall has a few issues though. Is the scale of the bricks correct? Also it looks a little flat and too reflective. Do you happen to have a normal map or better bump map you could use?
