Interactive won't render objects
I have a problem with a scene that renders fine, but when I start interactive, nothing renders. Well, the background image renders, but no objects show up. Corona 1.52, Max 2017. Anyone encountered this?
Edit: Works fine in Max 2016.
Edit 2: Nope, stops working in both versions after a while.
Hi, maybe this will help?
https://coronarenderer.freshdesk.com/support/solutions/articles/12000019571-objects-are-not-rendering-and-i-can-only-see-background-
try to move keyframes
Thanks for the suggestions, I’ll try it out on monday.
Moving the timeline marker back and forth worked. Still a bug, though? Has it been reported?
Edit: Even though it works when I scrub back and forth, it takes forever for corona to reload everything and start rendering.
Have you tried with the guide I sent in the previous message?
I’ve checked mine. The files and folder are not hidden.
It happens from time to time. Moving keyframes is my temporary solution.
check this out, https://corona-renderer.com/bugs/view.php?id=2089.
maybe you’re having the same case with that report.
Maru: Yes, tried that.
Christa: I can’t log in to the bug tracker, so I can’t check.
afaik you can just register there without any requirement.
I reported that few months ago in mantis. but even though there is no feedback yet, i’ll try to describe the problem I experienced here. hope it is related to your problem.
my scene is so simple, contained shadowcatcher and coronaoutput texmap. coronaoutput map is for shadowcatcher and direct override environment.
then I started IR with custom button (CoronaRenderer.CoronaFP.startInteractive()) and then nothing rendered, only the background appeared. it doesn’t occurred when using IR in rendersetup.
I recorded the problem, check the attachment. it still occurred in 1.5 hotfix.
Hey Noel, I think I have the same case as you. I always use that script as well.
