Interior deisgn of an appartment in Algeria
Design and render : Viz Corner
Corona+Psd.
Thanks to follow us here : https://www.facebook.com/Viz-corner-1033678546682305
Cmts and critics are welcomes!!!
thanks to admin
Corona+Psd.
thanks to admin
Ouch, de-noising gave it a really “impressionistic” look. ![]()
Yes Maru i’m agree with you, some tips to improve my works?
cause after 8 hours of rendering it’s still noise in the image, i tried to remove it in psd but no way
Are you using portals?
We could take a look at the scene if you send it to use at support: https://coronarenderer.freshdesk.com/support/tickets/new
You can put the file on Dropbox/Wetransfer, you can also remove some of the assets/textures to make the file lighter.
ah !!yes of corse, i’ll try it with portal to see the différence, thanks
