Hi there
This is my first interior design. Hope you enjoy it ?
Nice shots and cool image ratio. ![]()
(Looks like a more GI samples are needed, but you can’t control it, since there is no option.)
Thanks for your accurate point of view?
Seamwork and shadows are on point and add to the realism. Well done!
Most likely 3rd good job with Focus ??
Emad! wonderul images, very moody!
How did you achieve vertical shots?
@pibuz , to create such vertical shots you can just set the resolution in the Capture tab to “Custom” and then, for example, insert 1000x1875 (the resolution used by Emad), and create further renderings as usual. ![]()
Did u use hdri or not in this scene. did u use auto brightenes or manually
This is perfect. Congratulation. Can u tell how u did these scene, what did u use diffrent from default settings. For me this is the max of Enscape u did very nice work, amazing project and render.
Very nice work!
