interior exterior lighting
I am working on an aerial interior view of an apartment - I would like to have the sun shining on the building and through the windows but I don’t want this light to shine through the ceiling when I remove it to show the interior walls. Any way to do this - Hope this makes sense
cdi3d
Just reverse the normals on the ceiling so they won’t render when looking down into the unit.
Sample
Okay here is the view - should help explain what I am after -
cdi3d[/img]
It’s been too long since i’ve used Max, but in Maya there is a switch in the objects attributes which allows you to turn off visabillity to the camera. I’m pretty sure there is something similar in Max.
-Matt
yes ,Matt_3D is right,just go to object properties and turn visible to camera off. thats all .
Check out this post:
http://www.chaoticdimension.com/forums/phpBB2/viewtopic.php?t=7041
It is explained there.
And see my image results here:
http://www.chaoticdimension.com/forums/phpBB2/viewtopic.php?t=7061
