Got a chance to do this little interior job.. i know left & right wall is eating lot of space but that is where client had asked to stand and take view.. have to send it today, client is new so thought will take feedback from you guys before i email
Thanks you!
i think its a decent, well rendered image, although it seems a bit empty (but thats a question of the project budget)
i really like the curtain material, well done there!
carpet on the floor coudl use a bit more work probably…
Thanks for your feedback Martin, curtain is a image photoshopped in render
any suggestion to improve carpet? also i m trying to fill space with may be some more paintings.. i hope that will make it look busy..
great photoshoping then :)))
add some variation to the vray fur strands angles, perhaps use vray fur styler or scatter Bertrand Benoits carpet bit using Forest Pack Lite…which works on straight surfaces.
you can also make the fur more dense, tapper the tips of the fur strands.
yep! i think you got it spot on!!!
Decent image but the scale of door looks off to me.
Thanks Martin! Pixela@ i noticed this aswell but it is based on client cad data. ![]()
if the door has the correct dimension the wood floor is to big, they should be 6"- 15cm wide, they look like 8"
