Interior pool water
Hi guys
I am looking for a good material for pool water (interior). Ideally it should be transparent so that the markings in the pool are visible like in the reference attached. Does anyone have a such material in hand or a good tutorial for it?
Best regards and many thanks!
this one is based on Vray, but probably you can use the same principles..
Just set:
-diffuse level 0
-reflection level 1
-refraction level 1
-reflection IOR 1,33
-refraction IOR 1,33
add a bump map
and you’re done :smiley:
Then you can play around with absorption and scattering if needed.
There is also a “water clear” material in the Corona Material Library.
Thanks a lot! I will give it a try today…
Best
