Here´s two quicktime panoramas i did for a project that i started long time ago, and just
finishing now. Here is the Bedroom and the bathroom, i´ll post the kitchen and the living
room later.
They are in Hi Resolution, so files are big and compressed with Winace.
Hi ventil185! The images above look really nice having in mind they’re for testing purpose. I especially like the smooth lighting. What multipliers for the vray lights against what color mapping settings did you use?
Unfortunately, the qt panos take too long to download here… (the bandwith doesn’t exceed 3ko/s :? ). I’ll try to see those when I get more time and/or patience.
For the lighting, I used 2 vray lights for each window, one in the window
with multiplier of 6 with with as color, and another 1 meter away from the
window with mtp of 0,5 and light blue. I also used a direct light as sun
with multiplier 1.5 and light yellow as color map (this are my settings for
final renders).
This two last images only have one vray light at the window, as they were
just tests. I´ll post soon final renders with better quality.
