Reflections on glass on the interior is not picking up any of the modeled information and only shows the skybox. Is there anything I can do to prevent this or get the proper interior reflection?
Please tell us about your Enscape version and quality setting.
Enscape version 2.4.12
Using High Rendering at 1080 p, the rest are default.
Switch to ultra
That didn’t change anything with the reflections.
That’s odd, it shouldn’t be showing the skybox, and you should be picking up screen space reflections for objects within your field of view with simplified geometry for objects behind the camera.
Is this in the web standalone? (I have found that this is the behavior of reflective surfaces in the browser version.)
No its in the regular Revit plugin and also happens in Still Renderings and Video renderings
@nwergin , sorry to hear about that. Is there any chance you could please send me the project for troubleshooting purposes? Thank you in advance! ![]()
I’m experiencing the same issue as nwergin. Was this issue resolved?
@B.McCormick , please open the Enscape Visual Settings and check whether your rendering quality slider is set to Draft or Medium. If so, please set it to High or Ultra. Does this help?
