Interior Sunlight...
I’ve got an architectural interior project that I am working on and I am having some problems. My client wants to have a bright sun coming in through the windows casting strong shadows on the floor. I have tried several techniques (ies sun, Vray light with high multiplier, etc.) with little success. I always seem to get bright splotches in various other parts of the rendering (mostly the ceiling). I am using a linear workflow if that matters at all. Will the new VraySun be a solution to this problem? Does anyone have any suggestions of how to acheive this?
Ryan
Have you tried the standard direct light ? It works for me every time.
Good luck :slight_smile:
Edit: use vray shadows with the direct light. :wink:
Here is an very basic example of my problem…
IrMap - Low
HSph: 50
Interp: 50
LightCache
Subd: 1000
Ssize: .02
Scale: Screen
StoreDirect: Unchecked
The ceiling is diplaced via 2d vray displacement. I’ve tried IES sun, VrayLight w/ high multiplier, and this is direct light with x3 multiplier and an environment(skylight) overide with a sky blue color (multip. x1).
Higher IRmap rate settings only seem to result in smaller white spotches.
Any ideas? Would the new VraySun fix this?
Ryan
@ rfellers
Can you please send me the scene exactly in this state as it is now.
I want to do some tests with it. Thank you
< nikki@chaosgroup.com >
nikki Candelero
well with GI set to low possibly its because your GI is bleeding through the roof from outside or something
I think I solved it - problem appears to be with the displacement on the ceiling. Light was bleeding in through the roof from the outside as Da_elf suggested. Workaround is to create a box above the ceiling to block the light. Is this a documented displacement bug?
Thanks for the help,
Ryan
i think this is not a bug, but a geometry error caused by ur displacement.
the displaced geometry must be intersecting those beems or leaving some gaps in the borders… :wink:
sounds like your roof is single sided??
Vray doesnt like that too much.
u might also wanna do a LOT of reading and chek those linear work flow threads…it might give u a boost on that GI solution :wink:
