Interior toon line
On Domestika website there is a great tutorial for this kind of effect where you can get an internal details when using toon line.
Could we have this for VRay?
Hi, thanks for posting. I am not sure what details you mean? There are maps slots with the current VRayToon that you can use to add detail.
The toon effect in arnold can trace from a greeble texture map. When plugged into a ramp you can very the effect.
Could you share an example of this feature with a short explanation if possible?
Here is a link to best show the effect of edge detection with toon.
These are 2 clips from the training course which best explain the technique, you can simply skip through the shots to get the gist of the technique. of edge detection from texture files with toon.
https://drive.google.com/drive/folders/16cIawVR72cGgxlrAITO3ckwki8UnymwX?usp=drive\_link
VRayToonMtl > Toon Edges Override > “Mask Colour Threshold” cannot do this?
Yes it can! I was using a black and white image which didnt work it had to be colour.
Hey Flat, thanks for the pointer worked a treat.
I have come back this old thread as I need to reproduce this effect again but I can no longer do it..
This is the effect i’m trying to do.
Can anyone else try?
OK I got it. just map your texture into “Mask Color” then play with the Mask color threshold slider.
