This a new interior I am working on. It is a renovation of a childrens worship area for a church. Just a couple of test renders. All C&C are very welcome.
Justin
Re: Interior Vis
Nice work Justin. I think you need to increase the the Antialising settings. so you’ll get clean sharp edges (like on the ceiling and the curtains and wall’s corners) also set the adaptive amount (recommended at 0.85). It’ll help to get rid of the splotches on the black wall.
It looks like the 1st and the third image are the same. one final note is the bottom folds of the curtains, looks unnatural.
Overall nice work.
Re: Interior Vis
Thanks for the reply. I couldn’t find any good curtains on the 3D warehouse. o you kow where I could find some good quality ones? My adaptive is set to .85, is there any other settings that can help out with the splotches on the black wall?
Justin
Re: Interior Vis
For curtain you could use this plugin: [Plugin] Simple Loft alpha 0.1b -- UPDATED May-15-09 | sketchucation (you must register to download and view the images)
You’re using IR as your primary light engine, right? What settings are they?
Re: Interior Vis
IR Settings
-3 Min
0 Max
0.3 Color
100 HSph
30 Samples
.1 Normal
.1 Distance
Justin
Re: Interior Vis
Try to increase the samples to 50.
Re: Interior Vis
that loft tool is great!!! thanx for the link
