i want to try to recreate this interior modifying the interior design.
this is first step..
I’ve moved this to the dedicated WIP section
ah ok. sorry ![]()
are you using assert or release?
release
i tried to reinstall old version for have confirm but old dll doesn’t work.. is it normal?
does not work how? Fails on scene load, or max startup? What is the error message?
btw if you post the scene I’ll look into what might be causing the slowdown
error message in max startup, like problems to dll ecc
then the files were just probably overwritten badly. Try to download/copy it again and make sure you really overwrite all 3 files.
the error message appears when I switched from rc5 to rc4 .. Now I re-copied the rc5 files and everything works fine But I no longer 3,000,000 rays / s but 1,500,000, i upload the scene in Renderer for architectural visualization - Corona | Chaos
I had to simplify the scene but it is still slow.
have you received the scene?
yes, I’ll look into it immediately
you mixed up binaries from different builds
mmm.. how can i fix this? I tried to delete all files of a corna but maybe I’m missing something …
just make sure you overwrite all 3 files, that should be all. Check their timestamps
looks like the performance in the scene is completely killed by texture sampling inside 3dsmax. I’ll look into it further when I get to my workstation
