Interior with Corona Render
Hi i thought i would post an image of an Interior i have completed with Corona Render. I quite like the corona render. See what you think any comments would be appreciated.
at first look,
-lack of exposure or need a better lightning
-floor si over saturated i think.
Erick3d thanks for your reply. The scene is lit by a sky and sunlight which is only coming through the windows. Is it then best to have a couple of area lights by the windows to brighten the scene. What I don’t want to do is make it blown as over exposed. I will try to make the floor less saturated. Lightning a scene is by far my worse aspect of modelling.
Simon
Try to adjust exposure and when having too many burned areas just increase highlight compression
Hi jonnymrazko I will have a look at that tonight. For the image above I had a ISO of 80 and a shutter speed of 40. Should I increase both the ISO and shutters speed?
Simon
Increasing shutter speed will cause the oposite of increasing ISO value - higher ISO will result in brighter image and lower shutter speed will result in brighter image (I mean lower number behind the slash as it is 1/s). I would let photographic values go and tweak only simple exposure during rendering
