you need to tell everyone what method you used and your setting before anyone will be able to help you out mate…oh and as a suggestion.. lose the lens flare
i think the noise treshold in the qmc sampler thingy is 0.005 … i am also having those blotches in my visual, but i simply lowered the noise treshold to 0.002 or 0.003, it should be very smooth, but rendering time is increasing, any other method from you guys?
so to recap, if i change light cache to pre filter, lower my noise threshold to 0.002 and use world scale i should be sorted, i try that out tonight cheers
I thought the light light cache scale was best set at screen for still images. Surely setting it to world leads too high a sampling rate at objects far away from the camera?
