Internal Error: no RTTI data!
While doing an interactive render, I have seen this error. Although it seems that everything is ok
I was wrong, something it is wrong. I can not stop interactive render…
I’m afraid it might be impossible to tell what has happened, but if you haven’t closed 3ds Max yet, and you are still experiencing this, or if you are able to reproduce this, you can try capturing a minidump file:
https://coronarenderer.freshdesk.com/support/solutions/articles/5000524006
(see “2. Reporting errors or freezes if Autodesk Error Report window is not available”)
Today, I opened the scene and I rendered it. If it happens again I’ll do what you say Maru. Thank you :smiley:
minidump wouldnt help for this specific problem, but some instructions on how to reproduce it (video, scene, …) could!
hi,
any progress here?
The scene was the problem ended . And I have not seen that message more in other scenes…
Thank you for your interest :slight_smile:
Ive had this error, Access Violation - no RTTI data, on a message dialog with a title WTF :smiley: with the Corona Benchmark exe.
Render VFB was blank and just after a few seconds Corona 1.3 BEnchmark Error dialog states:
Couldn’t run Corona 1.3 Benchmark: Application exited eith errors. Visual C++2015 update 1 redistributable (x64) Failed
(ErrorCode = 1638)
(Press Ctrl+C to copy the message…
sh** Why have you not put this last sentence at the top :smiley: lol!
Anyway, rewoke the thread just in case it might help some other user solve their problem.
I’m running the benchmark because I’ve just tried to increase my ram speed to 1866Mhz on an X79 motherboard + Xeon E52697.
After loading default bios values, and manually selecting 1866mHz, I’ve had crashes two times.
The third time I managed to boot Windows in 1866mHz Dram speed, but this error appeared. Might have corrupt some distributable files - who knows.
I’ll try to ireinstall VC++Redist - to see if it works.
Reporting:
It seems its all about the hardware change. Reinstallation of the VC++ Redist did not help, but reverting back to the original ram frequency helped.
It works now. In my case, Xeon 2697 V2 at a memory frequency of 1866mHz did not work. 3DS Max also had a license issue, probably due to the resemblance with a hardware change.
