The GI is precalced using every 20th frame, which wasn’t enough or I should have made the FOV larger for the precalc, atleast there is some errors in the rim of the image.
Rendertime started at 2min per frame and decrease to around 1min per frame. Using a dual AMD2000
I still dont get it.. how do you make interpolated glossy reflections¿ I can’t find a way to do anything but sloooow glossy reflections :shock: Tutorial?!
ok, i know “it is right below the reflect subdivs” but the settings are in the panel Reflect Interpolation. (Material editor=> VRayMtl=>basic parameters(right below the reflect subdivs) and Reflect Interpolation
