invalid lightmap sample
What does it means?
It means that some sample in the light cache has either a negative or invalid (like infinity etc) RGB component. This is similar to the “Material returned overbright or invalid color” warning that you may get.
thank’s :smile:
ok, but so what? what can we do to avoid it or we can go ahead without worry with those warnings? and i would like to know how to let a negative rgb value positive, because this is one of the most commons messages we get around
It depends on what is causing the error. If it is a texture map, turning on its Clamp option (in the Output rollout) might help. If it is a shader (e.g. the error occurs even without any textures), then changing the shader parameters may help.
