I’m using max 2008 64bits (xp64) and vray 1.5 sp1…
All rendernodes return : an Invalid normal array error occurred the program will terminated
Any idea ???
Any idea ???
Sounds like a mesh problem to be, probably some object in the scene is causing it.
Thanks… I was thinking about something like that…
I’m using CAO files… Something unclean ![]()
Best regards…
Mesh problem for sure, try running a smoothing modifier on the offending geometry and see if that helps.
if you have loads of meshes you could try selecting half of them and then render, if okey invert selection and do the same again and again until you found the problem mesh.
It was a mesh problem …
A mesh from CAD software (Solidworks..)
Best regards..
