invisible in reflections ?
is it possible to set up an object, or a material, to be invisible in reflections, while being visible in the render and in the refractions .
Thanks!
Rayswitch material - https://coronarenderer.freshdesk.com/support/solutions/articles/5000529341-corona-ray-switch-material-and-map
yes, you can force for one material. But if i want to be for all the reflecting materials, it’s a bit annoying to set up, no ?
i was thinking about the option in vray_proprties where you can just tick the ‘invisible to reflection’ on a object, and it applies to all the materials
Hi
You can uncheck Visible to reflection/refraction from Object Properties dialog
Edit:
Sorry, it makes it invisible in refractions too. I should read posts more carefully…
yes indeed I knew that one :wink:
