IPR crash with Loop Selection
Win 10, C4D Studio R19, Corona Beta 1 Release.
  • Load the scene. “Ringe außen”, point mode and loop selection should be active.
  • Start IPR.
  • Try to “loop select” any point loop of “Ringe außen”.
  • Restart C4D (or go have a cuppa, or a beer).
CU
Michael
PS
It does not seem to be the loop selection alone, this scene really loves to crash!
PPS
Still getting there slowly, but since it is an object from “native” C4D, it contains the C4D AO shader. I’ve seen crashes with the IPR (not when “only” rendering to VFB) that went away when I got rid of C4D’s AO. Any hint of that in the bug report?
_BugReport.zip (27 KB)
ir crash.c4d (318 KB)
Hi Michael!
I cannot reproduce this with the newest Corona version on R19. Are you sure with the repro steps?
Cannot reproduce here either, can select and adjust loops and IR remains responsive.
I’ll retry tomorrow!
I just followed my own steps. Result attached. So - yes, it does crash.
Does the bug report say something useful?
_BugReport.zip (32.1 KB)
No crash here on my end following your steps…
Strange.
2018-02-24 20-21-21.flv (2.91 MB)
just glitches for a moment, but then flies again & doesn’t crash
W7, R18.041, Corona Beta1
Here are some tests in R18, OSX
it does not crash on loop but at HN disabled/enable… !
in layer AO is cause of crash (crash 5&6) but others also have to check.
Guys, one remark - the _BugReport.txt is usually way off in Windows for some reason, so it rarely helps us on Windows. If anyone of you tries this and C4D crashes on you, could I ask you to send us a zip file with the contents of the whole _bugreports folder? The most important file there is the minidump, which contains a reliable call stack…
Ask and ye shall be given.
I just took a minidump for you.
minidump.dmp (1.83 MB)
That’s a neat little pile of … data … you left there! Thank you :wink:
Your welcome.
Minidumpia non olet :wink:
So it turns out that it is the Ambient Occlusion shader that smells. Might be us not giving it some data it needs, but it also might be a bug in C4D. I am wondering if those people who didn’t have a crash have a different C4D version? I tried it on R19.053
FWIW, 18.057, B1 RC 2: no crash
19.024, B1 RC 4: crash
19.053, B1 final: crash
add AO to diffuse, reflection & refraction, with volumetrics, mix in another subD, plus couple extra deformers… oh, still no crash :frowning: w7r18.041
slow… but thinner it is the darker it gets
First Beta 2 daily plus 19.053: no more crashes.
Moving to resolved then. Thanks for feedback, Mike!
