IPR crashing with Forest Pack Forest Edge map
Hi!
I am experiencing 3ds Max crashes when using a Forest Edge map in my materials. It only happens when I am using the IPR, it renders fine when I am using the regular renderer.
I contacted the Itoo guys, who told me to contact you :smiley:
Here is the thread from the Itoo forums:
I will also upload the minidump I recorded using ProcessExplorer, as when Max crashes it just shuts down, there is no error message at all.
Vincent
Here is the upload reference:
1576178328_3dsmax2.zip
Are you able to send over your scene so we can try to reproduce the crash here?
Thanks,
Rowan
I just uploaded the scene on your dropbox; it is called β€œ060_entrance_v004”.
On my machine, starting the ipr crashes Max shortly after doing so.
As a side note, in the end I am not going to use the edge mode because it causes flicker in the animated grass (blades appearing/disappearing).
I created smaller clumps and used the regular point mode.
But still, it would be interesting to understand what’s happening :smiley:
Thanks!
Vincent
Thank you, we will investigate it. Can you confirm which versions of Corona and ForestPack you are using?
Cheers,
Rowan
I am using Corona 5 and the latest Forest Pack 6.2.2.
Thanks,
(Internal ID=435709873)
