IPR does not update
The Vray Material updates very inconsistently in IPR. For example if I change the color from red to yellow it will not update at all. Only when I re-render does it appear correctly. Similarly, if I lower the glossiness or amount slightly the highlight completely disappears. Only when I re-render does it appear correctly again.
This appears to only happen with the Vray Material. The Maya materials seem to update fine in IPR when rendered with Vray. So do other Vray materials like the Fast SSS2. It only appears to be broken with the Vray Material.
This should be much better after we finish some of the current changes that we are working on.
Cool. How would one get those changes once they are done?
Through the nightly builds as usual, and after that in the official updates.
